New system plans for Christmas
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Hard to hook up? What happens to the stock volt meter?
As far as I've seen is it doesn't effect the stock one. And hooking it up was pretty easy, you only have 3 wires: remote, ground, and power. hooked it up through the radio harness. The only bad thing about it is if I want the whole dash to come off a again, Ill have to disconnect those wires. I need to make something so it's detachable like everthing else. Any suggestions?
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
They send you mounting screws or you can use double sided tape they give you too. Then just drill a hole for the wires in one of the open spots on your dash. I wish mine was where the 4x4 switch is at, but oh well. The wires arent long at all, so you should have it in the same general area as me, or you can buy some longer wire. I just went the easy way lol.
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Hey guys I was looking at this alternator and wondering if this is good enough for what I'm getting. Also will it directly bolt on to where the old one was?
http://www.db-starter-alternator.co... HIGH 220 AMP OUTPUT ALTERNATOR 96-00 8206-5
Narco
Atlanta
ive been following the thread...cant wait to see the btl
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Well today I was a little bored and I ran my power wire a little bit better, and think I'm moving my ground. I'll show where my ground was, and I guess I should do it to the frame, but I dont have enough ground wire for that. Will the ground I have now be good? Also mounted the amp on the box, and ran the speaker wire from amp to inside the box. Just some boring stuff... Heres some pics
Amp mounted
What the wires look like on the inside
Heres where the power wire is ran
Where is comes out and here is where my ground question is
Capeles
