It means how the wheel is centered to the hub.
Hub centric means they center themselves off the hub via a little lip.
There are lug centric wheels that center themselves via the tapered lug nuts
https://www.discounttire.com/learn/hub-centric-vs-lug-centric
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
The bumps your referring to are the lack of sidewalk in the tires. I guarantee is you go to 18’s, the additional sidewall will pick up the off-highway bumps.
With more sidewall, the body roll and/or worn sway bar bush are going to be more pronounced. Upgrade the bars and go poly bushings. You won’t believe the difference.
You got a really nice rig. That paint has a lot more clear than standard colors. Ceramic seal it ASAP to avoid the peel that’s overdue and ready to occur. It’s a difficult color to match, but deff my favorite.
Retractable running boards? They look good! Keep the oem AutoRide bags and struts filled with magnetorheological fluid. Unlike the normal struts they’re 100% efficient until they fail. The 22’s will sell themselves on c/l. Find a wheel tire comparison calculator on the internet to get really close or perfect on your tire selection.
Welcome aboard!
i was just surprised at the amount of body roll. seems like what i was reading about was saying how the magnaride road rough/firm. i will check out the bushings and sway bar.
You have the AutoRide Suspension Package, RPOs Z55 and G69. Magnetic Ride Control was reserved for the Cadillacs.
Check all of your shocks for movement and your air compressor for proper function.
