BUILDINXJS
- Joined
- Feb 4, 2013
- Posts
- 8
- Reaction score
- 0
New member first post I Just bought a 98 2 dr 6.5 litre electric 4WD I think pretty much power every thing The PO was not available to explain any thing about the vehicle. First problem I have fixed I think was pwr seats did not work so I replaced the relay and now they work.I finally got 4 low to work and the SERVICE 4wd light came on but it did pull up a steep muddy hill that it would not climb in 2 wheel so I wonder about the service light?? Also can someone explain the 4 wheel auto, 4 Hi, and 4 low shifting procedures.Also what is the red neutral light that stays on in 2 wheel that is located next to the 4 wheel switches.Also when I got it the transfer case fuse inside the cab had ben pulled,what amp fuse should be there? I installed a 15 and it popped so I put a 20 in and it has been good since.I've only owned it for two days and I know there is a lot more I will have to do to it soon.Thanks in advance And I look forward to learning from all of you here.
