SUNLIT thanks for the reply I will check those connections. After having cleaned the speed sensors replacing the front brakes checking ABS fuses for power across them and disconnecting batteries the ABS light is still on, Any thoughts on that? I am still puzzled about the 4WD service light because you can hear it lock in and 4WD with out a doubt is working in 4 hi and low not certain about Auto mode but the service light still comes on, fuses are not blowing out. When the light does come on I have to turn the engine off and remove fuse 2 in order to shift back to 2WD very strange to me. I really appreciate your help.
