New to the forum - 1997 Yukon
Stunt
Hi there, I'm new to the site and to the USA. I'm from Edinburgh in Scotland and am over here for a 6 month visit, traveling around and seeing as much as I can from the drivers seat of a 97 Yukon. I've had the vehicle for about 7 weeks and have travelled over 7000 miles so far, not without some issues, as you may imagine !
The interior fan switch was fried, so that was repaired; the starter motor died in Upper Michigan; the fuel pump control/fuse was shorted/burned out so that got fixed.
Now a couple of questions for you - the brakes have a really bad judder when slowing from normal road speeds, but it's not emergency braking causing the ABS to activate. The rotors and pads were replaced not long ago. Any ideas about that ?
Also, when traveling at normal road speeds at normal engine speeds, the car develops a serious vibration at the wheels (I think). It feels as if I'm driving over those rumble strips you get at the edge of the highways, but several times worse ! It happens when traveling at around 42-44 mph, 47-48 mph and 52-54 mph, and at engine speeds of about 1500 to 1800 rpm. This can be defeated by increasing or decreasing the road speed, but I don't know what might be causing it. Again, any ideas folks ?
The vehicle is a 1997 Yukon SLT1500 with about 180,000 miles on the clock. It was really clean when I purchased it, with evidence of good maintenance, but little or no service history.
Any help or advice will be much appreciated.
Stunt
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
Your brake problems most likely sounds like you warped your rotors perehaps from an incorrent pad break-in.
For the other vibrations at speeds you listed with no brake it is usually pitman arm or idler arm or mount.
BluHoe96
How long was the truck sitting before you bought it? If its been a while the tires could have flat spots also.
bambam
Flowood, Mississippi
shaking issue could simply be tires out of balance especially if it smoothes out at higher speed find someone with a hunter road force balancing machine and check that could fix the whole problem there and although rotors are new it is not uncommon to get a warped one from factory causing the brake shutter
marktorres4242
