New trans install questions
Fleetgeo
how you guys doing today more questions for my 2001 Denali 6.0 85k miles
I'm installing a new transmission got off a escalade with 87,000 miles what else should I replace while doing the removal and install
What do you guys recommend doing to the trans before install
New trans gasket and filter ???
02_Tahoe
Maryland
Is it a 4l60e? Corvette servo if it is
SnowDrifter
Washington. The desert side not the Starbucks side
If/when you do the corvette servo(very easy), 2 big things to be sure of:
1. Put the 4th gear(outer most) apply piston in the cup, then put that on. Don't put it on the rest of the servo back then try to put the cover on. The teflon seal can pop out and get pinched during install if done another way, I learned that the hard way
2. Make absolutely sure the circlip is seated in all the way else your cover will pop out and you lose fluid. I've also heard of a couple instances where the cover gets cocked at an angle and the fluid pressure causes it to crack the transmission case. So make sure it's in there good!
Fleetgeo
Fleetgeo
Thank guys I appreciate all your advice really helpful stuff Man thanks again
MrBalll
West Texas
May not need it but may not hurt to replace the rear main seal to just prevent a future issue.
rockola1971
Indiana (formerly IL)
I would change the rear and front seal then the filter when its installed. Make damn sure its full when you first start it up!
Roscoe2352
