NO Air Out Of Front Floor Vents REAR HVAC Not Working Properly Related?
jmm121783
jmm121783
Searching for the next sunset...
Detroit
gonna take out the speedo today hopefully and see whats up with the lights
HAPPY THANKS GIVING EVERYONE!!!
jmm121783
jmm121783
Detroit
has anyone bought one of these supposed Tech2s off of ebay for $350?? That seems way too good to be true.
MidwestMike
Southwest Michigan
You can do a reset of the actuators for testing. You can do a search, but I believe it was as simple as taking the battery cable off and turning the ignition key.
There are also more detailed versions, that may not fit or be needed.
https://sparkys-answers.com/2011/08/hvac-actuator-recalibration-procedure.html
I would start with just the battery and key and see if it works for you for one cycle, then a little search will tell you which actuator.
The heat/cold one is easy enough under the passenger dash, there is another one center/driver side that is also accessible. Another one is a whole dash project (some other vehicles require the windshield to be removed..)
flipharvey187
