rfried
Forum members...As I know this topic has been brought up before, I haven't found one to go this far into diagnosis.
2004 Yukon SLE 5.3, 220k miles.
No crank, no start has been going on sporadically for the last month. Following all information I could find, I started replacing items one at a time. First, the battery and alternator tested fine, all grounds and positive cables to battery, alternator, starter, and frame are in good working order. Every time I replaced something, vehicle would work for a day, then wouldn't start again. Sometimes it sat over night, sometimes it sat for a few minutes. As with the other write ups, all lights work, no other electrical issues noted.
Items replaced so far:
Starter relay
Ignition relay
Crank fuse
Every fuse, under hood and under dash, marked IGN
Ignition switch
Starter
What else could it be? I guess I'll replace the key cylinder...I can't think of anything else?
Suggestions?
Starter relay
Ignition relay
Crank fuse
Ignition switch
Starter
Suggestions?
