Dr Banana Maann
- Joined
- Oct 21, 2015
- Posts
- 7
- Reaction score
- 0
Ok so digging around under the dash I cam across this strange chip that when out just disables the start on part on the ignition. It attaches to the Yellow wire which I believe is the "Crank" wire. There are 4 other connections. 2 going to the same ground post, another 1 the red wire is going to to this orange wire near the obdII port. the crank wire is cut and is being fed into a relay as well.
The chip itself is very small and has just 4 contacts if I recall. I will try and get a picture of it tonight when I have some time but I don't have a picture of the actual thing that is mounted on the underside of the dash as well as a crappy pic of the relay.
1996 Chevy Tahoe 5.7L, it does have a trailer braking system as well.
