No more woodgrain--AND NOT PAINT
B.G.
Looks really good man! I actually contemplated that once.. Dont worry, that wont discolor. Real CF will discolor if the proper resin isnt used. And it most instances those are exterior pieces.. 3M di noc is good stuff and wont fade at all. Man, how did you pop off those pieces.. I tried for the life of me to get the a/c ones and the stereo ones off and had no luck! I only ended up getting to door ones off. Any advice?? Do you just need to pry harder. Crap looked like it was gonna break though:?
Sweet_N_Low
Sweet_N_Low
When you get a little leverage look behind to where the clips are and try to get your hands as close to the clips as possible, give it a quick jerk, see if that works
Quikzilver
Lake Worth, FL
I'm hoping my 5% tint will help eliminate that. Did you use the high end 3M vinyl?
Yes, I did use the 3M vinyl. But 5% window tint should help you out. My SS is tinted in the rear only, so hopefully it will hold up better for you!! Again, looks really great!!
Sweet_N_Low
Sweet_N_Low
What is the material called (please don't say carbon fiber lol) do I just search for 3m vinyl?
It is 3M di noc, it's all over eBay. 12x60 piece did everything I did with some extra and it was $31
Administrator
How are the trim pieces held in? Is it just by tabs and you just "pry" them out?
tfol
