No oil pressure at start up, 2001 Tahoe
JonnyTahoe
Minneapolis
I wish I would of ordered a new Oil Tube because they are cheap and would of been nice to have a new one after doing all that work but most people probably don't think of it so you clean up the old one the best you can and get your truck back on the road.
JonnyTahoe
Minneapolis
Summajet
I am impressed with the mileage. Keep the wheels turning.
My m drives an older 95 dodge ram 4x4. He said if/when motor goes he is replacing with another motor.
I asked about just getting a newer you and he advised no.
Supergmc
I've got 390k on mine and I did end up replacing the ENTIRE braking system due to previous owners neglect. And a few emmision valves. Dashcluster and the water pump blew apart well I bought it with the water pump blew apart.
dukbludvl
I put nearly 400k miles on my 2000 Yukon 5.3 2wd. Original motor, did replace the trans after 161k miles. For about the last 100k miles I had this same low oil pressure on startup issue. Wish I would've known it was such a simple fix. In the end, it had some other issues when I finally gave up on it -- likely a leaking head gasket, was getting coolant in the oil. And finally the radiator went, that's when I quit on it. I bought this one new with 6 miles on it and I put all the miles on it except maybe 50 or so when I had a DD drive me home a few times.
My second Yukon was a 2005 5.3 2wd. Bought it with 191k miles and ran it up almost to 300k. It too developed the low oil pressure on startup, probably around the same mileage as my first one - maybe 250-275k. Transmission went on it and I decided not to repair it. Still have it, going to look to sell it I guess.
I'm now on my third Yukon from this body style. A 2003 5.3 2wd. It's a 1-owner vehicle I got with about 150k miles. Original motor and trans, no issues. Oil pressure is strong. At least now I'll be aware that this is a cheap thing to look at if I ever experience the low pressure problem on this one.
Love these vehicles from the 00-06 era. Would drive one forever if I could. Also have a 2012 Tahoe 5.3 4wd. Got it with 77k miles and it's now at 180k. It's been a solid truck, but the seats are way uncomfortable to me, and I don't love the active fuel management. Other than that, no issues at all. Still runs like new like when I got it from the previous owner. Knock wood.
Merc1973
Maryland
Well my old pressure finally goes to 0 now it idle. Normally at idle it would be about 20 and the highest it high RPM at 40. I have 283 k on it right now I have four wheel drive how hard is it to drop the front axle a little forward?
Stalis
