Mikemustang289
- Joined
- Jul 14, 2018
- Posts
- 5
- Reaction score
- 3
Having a weird issue with my 2000 Yukon Denali. Its the older body style with a 5.7 V8. The truck has been randomly not starting over the past few weeks. I was thinking the battery might be getting low or going bad. Yesterday it left me stranded in front of autozone (lucky for me) . I noticed that when I turn the key to the ON position I dont hear the fuel pump prime and when trying to start it will just crank as though its getting no fuel. I checked the fuel pump relay and it bench tests good, also bypassing the relay with a jumper turns the fuel pump on so I know the relay and pump are good. So while stuck at autozone and having no luck getting the engine to start I bought a battery and swapped it out. The battery that was in the truck was only putting out 12.3 volts. I put the battery in and it starts right up. I drove it around yesterday with no problems. Parked it last night and set the alarm. Today I try to start it and again the pump is not priming and it wont start. I disconnnected the battery for a few mins, reconnected it and it starts right up. I'm thinking now the issue has something to do with the alarm. I'm going to avoid locking the car with the key fob for now to see if the problem continues. Anyone have any idea what might be causing this issue?
