Noise in driveline, pinion bearing?
B-train
I'm stumped, but after seeing both videos, I see what you are staying. In my experience, a pinion will make more steady noise as rhe rpm of rhe driveshaft increases. It won't be rhythmic. A driveshaft will give a rhythmic drone. The run-out seems a bit much, but I don't know what GM spec is, nor have I put my own on a lift to look at it. There have been numerous complaints over the years with aluminum driveshafts, to the point of litigation. I've had a rhythmic drone on my 2017 Denali at 75-85 mph forever. I found a bad u-joint and that helped a lot.
If you bent an ear doing a u-joint, I'd start there. Since you said it was there beforehand, is it possible that there was previous wear from a tight joint that you are now hearing? Resonance problems can be a *****....just have to sort them out process of elimination.
You could try removing the rear shaft and driving it. Since it's AWD, the front should pull it along. Maybe then you can see if the noise is still there or gone.
Just like an old school straight axle with a blown rear driveshaft......Limping home in 4wd. Not that I've ever done it....LOL
j91z28d1
I beg to differ. I have changed many pairs of u-joints and heated the keeper/epoxy to melt it out. The heat is not that much really. You are not heating it like you are getting ready to cut metal.
I get it, but I don't think I'd trust anyone I didn't know personally to do it. I don't think I'd try it myself. his looks alum like mine? I guess the steel ones would be easier. but eh.
GMT800 SUV/Trucks
When I did my first heat 'em up and melt them out, I was amazed but I did see one thing though, PITA to clean out the grooves for the new snap rings. But was doable. I honestly never had a problem doing it. Patience helps so you don't overheat.
Donal
Americus Georgia
I won't get to it today, but will dive into tomorrow hopefully. My luck will be it's too tight and I would need to replace the crush sleeve and likely the bearings, or rebuild the rear.
I can't tell for sure but under a good load if there is a faint growl starting, it might be masked by the exhaust. That leads me another topic I've been meaning to bring up. The exhaust looks OE but it seems like it has a little more bark than other 6.2 GMT 900's I've heard. Steady cruise is quiet, but under acceleration it has a nice exhaust note..or how crazy would it be that it's actually a pinion.
Thanks for that.
For the 8.6", does this rotational torque include the axles or with them pulled? Or just the calipers removed?
calipers removed
D
dkad260
Mine is steel.
Sorry for the late update but here's what I have found. I removed the brake rotor and saw the seal was wet, so I pulled both axle shafts and the RH had nociceable pitting on the shaft, as well as small very fine pieces of metal laying between the bearing and seal. There was about .030" of vertical movement of the axle, maybe a little more. The LH axle looks good but has some verttical movement as well but only about .010 but still alot.
The backlash is .010, which is a bit more than I hoped but right at the limit, mesh pattern looks like it may have a slight bias towards the heel, could be from the pinion seal replacement or could be what was there from the factory, that part I won't know. Coast side did look good.
There were no shavings further down the RH axle tube, none in the pumpkin and none in the LH tube and barely anything on the magnet...so I think I caught this early enough. Safe bet that would cause a fair amount of noise.
I have two new axles/bearings to go back in, I also saw a good bit of tearing on the ABS tone ring where it grips the axle so I will replace both of those as well, which is proving to be a chore finding the right tool to install them, but another story.
Geotrash
Dave
Richmond, VA
Mine is steel.
Fantastic update, thank you. Looks like you’re on the right track.
Mine is steel.
We know all the right tools to pull and install them.
Axle shaft end play can be no more than .012 inches per side. Radial play between .002 and .003 inches. Ring and pinion ought to be between .005 and .007, .010 is the max.
dcobbs17
