Noise steering drag? Front differential? Auto 4WD
K
KR66
I was thinking of getting 2 used CV axles and cutting the shaft down so only the spine was left this would effectively disconnect the front wheels from the differential! Until I can replace it see the photo of what I was thinking of doing this should not affect the suspension negatively just won’t have 4WD, I will have to remove the boot from the spline side of the axle and remove the shaft and bearings so there’s nothing left except a solid piece with the spline to hold the hub together.
K
KR66
I know this is a bandaid but I just dumped over $4000.00 into it and the $$$ are a little thin right now I thought it would have been something I replaced already the 3 garages I took it to kept saying the hubs or the CV joints even after I replaced them now that I have actual video and audio from under it while driving there’s no other explanation for it! How bad the Differential is? iDK? Maybe something easy to fix I did put almost 10000 miles on it with this problem and nothing has blown up or fell apart? This is one of those oddball issues! I’m thinking the previous owner ran it in 4H on dry pavement and messed up the front Diff
Chubbs
Before you direct 100% attention to the front differential, perform a thorough inspection on the diff' output bearings if you haven't already. The bearings & seals are inexpensive but the labor is fairly intensive for what it is. I definitely wouldn't replace the bearings & seals only without completely eliminating the differential as the origin. Draining the oil into a transparent container and sweeping with a magnet for metal particulate should prove a reliable indicator for any damage or ongoing fault within the carrier assembly as there would be visual evidence associated with such a problem.
if the output seals were compromised earlier in the vehicles history and fill level remained substantially lower than spec, bearing lubrication would become non-existent & the precursor to a failure. Check the fill level with something flexible before it is drained off so that you can apply it towards the diagnosis.
In conclusion, if the gear lube fill level is low and saturated with discernible metals = diff failure. Then a low fill level with no obvious metallic contamination = output bearing failure.
If the oil has not met the minimum factory requirements for removal/replacement there will be an obvious odor & color factor which is why the fill-level & metals saturation the reliable indicators.
I probably overlooked your confirmation of the service history or latest service which is why I went into detail so I apologize.
K
KR66
I serviced both the front and rear differentials about 4000 miles ago and used dealer purchased oil, when I drained The front Diff there was a little bit of metal on the magnet built into the drain plug but I didn’t think it was excessive for 270000 miles, it’s was a bit thick it it may not have been serviced in a long time. I did find s video on replacement of the output bearing on the drivers side, Your right it’s a lot of work! I may get a gasket and pull the cover to inspect the inside if possible? It it’s trashed it may be easier to just replace the whole differential! And rebuild the one I pull out.
K
KR66
Do you think a bad output bearing was bad do you think it could cause a intermittent drag? I also noticed a Burnt oil smell after driving a while I thought was a leak from the engine somewhere but I think it’s coming from the differential! So it could be the bearing as you said
Chubbs
Careful, now...
http://www.tahoeyukonforum.com/threads/psa-cheap-hub-assemblies.101520/#post-1217904
You effectively want to isolate the front wheels @ the hub per this project?
K
KR66
I will have to check it closer I hope the bearing race isn’t seized into the differential if it’s getting hot enough to burn the oil. If it is the differential housing may be scrap? I’m going to look at it this weekend if the rain stops.
Chubbs
Do you have a shop manual? Some of them contain diagnostic trees for problem solving various parts & systems
From what I recall there is only a press fit bearing & seal on either end. I haven't come across a single piece of literature or thread/testimonial of a spun output bearing. It's a needles in cage type of deal prob designed to self-destruct before interfering with the housing. I couldn't imagine a design where 1 would have to scrap a $2500 axle on account of $10 bearing
Some manual call for removing the whole damn axle to R&R bearing/seal but it can be done in place if you have the right $hit & know what you are doing. Saw a few vids on YouTube if you need a ref. But I don't want us to get ahead of ourself
You watched a vid for DS output bearing on YT: if it was the guy who removes the knuckle/spindle before first supporting it and has the lower arm unload full force, I would only ref that entire thing as "what NOT to do." That goof troop learned everything the hard way & proves a workshop manual is usually necessary as not to continuously overlook both the obvious & inconspicuous
I'm anxious to know what you will discover. Will be looking for updates. You are correct about servicing/rebuilding a donor axle then do a complete swap. Just have to match rpo build code for R&P ratios
certa
