North to Alaska
William Sharpe
Hey I'm new to both the Tahoe world and this website so be kind with my ignorance.
I am moving to Alaska and I just bought a 1999 2DR Tahoe 4X4 and I need to get it Artic ready does anyone have a list of things I need to do as far as what oil and antifreeze to put in it to be ready for -60 degree weather ?
h0tr0d
Brenham, Tx.
Probably should invest in an engine block heater for sure. Some people run special blankets in the engine compartment. If it really is going to get that cold where you're going, you'll need a cover for the grille opening to limit airflow to the radiator, or it will never heat up in weather that cold. That's all I've read about...hopefully someone else will chime in here and help you out more.
P.S. You're crazy!
moviewithnotitle
Jersey
Good luck, it sounds chilly! I watch a lot of Ice Road Truckers and I have respect for them, and you for moving.
I would suspect that your fluids are gonna have to change. In cold climates you have to run a real this viscosity in Oil and Tranny fluid. I think gearcase oil is fine, but everything has to be rated for the low temps you're gonna face. If you can, I would try talking to mechanics in the area, or at least hit up Chevy and start asking questions about the climate and preparations.
Definately a grill blanket, and engine-block heater are a must. I would also suggest heated seat covers if you don't have them and remote start!
Keep us posted, could be a good way to transfer info to others that would like to know.
99Yuk
Northern Ontario, Canada
Well, I'm from up North, not quite where your going though. I only average somewhere between -30 and -40. I think my own personal record is seeing -45 in the mirror one morning.
There are several things that I can think of off the top of my head.
Install at least one block heater, if not two.
Install a magnetic heater on your oil pan.
Install a battery blanket.
Purchase a propane tiger torch to melt your oil pan, in case you forget to plug all that in at night.
Install plug caps! Keeps the crud out of the prongs, and keeps the prongs around longer than a year.
Migrate away from 10W30 to at least 5w30, if not even 0w30. I like Castrol?
Change over your orange dexcool to regular green stuff. The orange stuff over time gums/freezes up the smaller passages in the engine block. You should see the pics from my old engine block.
Buy one hell of a saftey kit, including a wollen blanket and food.
Make sure that you get your truck undercoated. I personally use Krown on mine. After seeing my dad's old beater truck after 14years and very little rust, I'm convinced. He bought that old truck new and had it Krowned every year.
Oh, and install studs on your winter tires. This year, I'm going for Winterforce studded tires. :)
That's all that I can think of.
BTW, your crazy going that far North! Welcome!
puckhead
CO
I havent really done much to mine except make sure your coolant is good and change the oil regularly. Also have a black heater. Gets down to about -40 here for a good part of the winter. Hope it works out for you!
drowndindreams
Unknown
a roof rack, lift, tire chains, hand warmers, seat warmers, and maybe a salt thrower :)
RSymons
Texas
Sounds like a adventure, i have entertained the thought of moving to Alaska more than once. Good-luck and have fun!
Effeckt
Resident Cards Fan
Phoenix, AZ
Welcome to the forums and good luck with the move. I'll save the advice for the experienced. We don't know what cold is here in Phoenix, we have the opposite problem here.
Tahoe06
Welcome to the forum, good luck with the move. I wouldn't be able to give any advice, I'm in the same situation as Effeckt, except I'm down in Tucson
Dremar79
