not balanced??
whitexfe
houston, tx
I just put on some brand new 24" KMC slides mounted with some Nexen roadian tires and I only have about 3500 miles on them and they seem out of balance. It has a good vibration around 60-70 mph.... Any ideas?
yates ™
Resident Apple hater
Iowa
I would take them to another shop and have rebalanced.
THE YETI
Director of Operations
South FL
high speed balance them, too. not just standard balancing.
InTruckDesign
SW CT,
Remove the wheels and check that the little metal clips that hold on the rotors during production are removed. They will prevent aftermarket wheels from sitting flat to the rotor, factory wheels are machined to fit with them on.
THE YETI
South FL
I was going to suggest this too but figured the problem would have been obvious at all speeds from day one. But definitely check into that!
OBSalsoNNBS
