now what's wrong?
replaced plugs, now I have a slightly rough idle,can you please tell me what went wrong! check engi
  • Total voters
bottomline2000
Dallas, TX
pull the plug wires one at a time and see if the idle changes. the one that doesn't change the idle is the problem. I had a plug wire pop off and my check engine light started flashing. Chances are you got a bad plug or plug wire not plugged in correctly. had the same issue on my sons Accord and it turned out to be a bad coil pack. found the problem using the same method.
H
heavy d
Thanks I will try that, I knew it had to be something simple
wiser1
