o2 sensor question
97blueyuk
Okay so my p0430 code came back. I am trying to swap the sensors side to side. I have the sensor sockets, but am having quite a bit of trouble with the bank 1 sensor, not much room to work around there. Any tips or advice??
thanks
saif najd
I wish if I there is an emulator for this sensor I have the same code daily
Sent from my GT-I9505 using Tapatalk 2
kcb37
Did you get it out?
I do not own a O2 wrench or socket.
I have always used a regular wrench, cresent wrench, or when they are real tight a pipe wrench.
saif najd
Did you get it out?
Me no, I had an accident so every thing is on hold :(
97blueyuk
97blueyuk
actually, the one that was throwing the code was the one i thought would give me the most problem. I did get that one out pretty easily. The other one was giving me problems. The o2 sensor was only 30-35 bucks from amazon so i figured put a new one in, instead of fighting with and possibly ruining a bad one too.
i got it out after soaking it with liquid wrench, letting the truck run for about 5 mins and using the o2 socket.
LA SILVERBIRCH
Im getting that same code on my 99 2 door tahoe the o2 sensors were replace about a month ago i am thinking that i have a clogged up catylitic converter because it feels very slugish as if i was dragging an anchor at but only at wide open throttle.
saif najd
I feel the same and my catylitics are empty :D
LA SILVERBIRCH
i feel the same and my catylitics are empty :d
sent from my gt-i9505 using tapatalk 2
deleted my cats, did new ac delco plugs and wires with rotor and cap also did new fuel filter cleaned the throttle body and did some seafoam in the vaccum hose that goes to the booster and i gots to say that it feels 100 times better.
saif najd
Sea foam!!!
What is the story with the sea foam please tell,
audley71
