Odd no start issue 03 Tahoe.
Smoke Em All
Smoke Em All
Taylor,Texas
Yea I'm planing on carrying a can from now on but I'm trying to figure out how without the entire cab smelling all the time.
Sent from my iPad using Tapatalk
jimg2347
So this issue has been happening to me for a while now but it's so random and not exactly a regular occurrence. It may be a little difficult to explain or understand without actually seeing it happen but I'm going to attempt it.
On occasion when my fuel gauge is around 1/4 tank my truck won't start. For a while I thought the gauge was wrong but I have since proved that not to be true. I can drive it till the low fuel light comes on with no issue. The strangest thing is if I put 4 gallons of gas in it it will fire right up. I specify 4 gallons because for some reason one 2 gallon gas can doesn't do the trick. Now also keep in mind that this doesn't always happen usually it will happen at 1/4 tank and at least 8 hours of no run time. On occasion if it's anywhere below half a tank and it's been sitting for a couple days it will occur as well. Never occurs above 1/2 tank.
Any ideas??
Could be dirt or rust in the tank. I had this same problem with a Bonneville, I dropped the gas tank and flushed it out. Solved my problem.
Capeles
