Odd sensation on acceleration from full stop
mountie
( My 2 cents)...... My great / old '88 C2500 was great... I put it on a lift.... I was astonished how easy it was to find loose steering / suspension issues. ( I rebuilt everything )
Put it up in the air. You can easily find problems, by checking the movement, due to everything hanging 'loose' , and other mounts / bushings, etc, can be easily checked.
SRQYukon
Sarasota, FL
I'm with Mountie. The best way to find anything related to suspension noise is up on a lift. With the ignition unlocked (so the wheels will move) have someone grab a front tire and move it back and forth while you look underneath. That will show worn tie-rod ends, idler or pitman arms. While its in the air you can inspect struts, universals, half-shafts, etc. If all looks good, then its probably internal.
J
jyi786
Update: took it into the shop. Had the most experienced tech take a look.
The front differential bushings are perfectly fine. What is shot?
The motor mounts.
Funny thing is that I did the motor mount test in my driveway, and didn't think I saw much engine movement. But when he did it? It looked like the engine moved way more than I thought. I don't know why I didn't see it. He also explained that's why I feel the thump/lurch when accelerating, and why I'm hearing the clanking noise randomly.
I've set an appointment to get the pinion seal and both motor mounts changed Tuesday.
PG01
Up here to the right
Yea..... You are right.......
Up on a lift will allow you to actually see if one or both are bad..... ( plus you can wipe off stuff to keep the bottom pretty )
If it ain’t leakin oil it ain’t a GM.... wait.... i mean harley..... meh....whatever :)
Rome58
