Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
ThwopKing
Bunker Hill, WV
No and yes. Everything clears, but sharp right turns combined with bumps-dips my drivers side rear tire hits the wheel well liner. But that's because theres a bulge for the autoride compressor. So a typical non autoride tahoe would not hit. I need to find out the offset on these ltz wheels, might get 1/2" or 1" spacers.
Ok cool thanks im liking your original setup.... not too high... not too low and i kinda wanna run that tire size because i can still get all terrain tires i still wanna run.
Sent from my SM-G960U using Tapatalk
05Single
afraid of the dark
Yea it's perfect for fitting a factory size tire. Still have a ton of sidewall for ride comfort.
ThwopKing
Bunker Hill, WV
I actually wonder if it will be enough drop now..... the truck im picking up was a government issue truck and basically has Z71 suspension. I'll take some measurements when I get it home.
05Single
afraid of the dark
Should be same exact measurements after drop.
ThwopKing
Bunker Hill, WV
After picking it up not sure if I wanna try a basic rear drop to level it out first or go for the full mild drop all around lol
BADRIDES
I've got a rear set of belltech springs for sale if you want to level it out.
1bdhoe23
Belltech drop shocks on the front, dim spindles, 3" keys, rear air shocks and helper bags(drag race often so it launches very hard with them adjusted) modded sway bar links front and rear, custom spring rate 5.5" rear springs, notched frame, belltech bumps, Spohn Panhard, Spohn uca and lca. I sit 30" in the front and 31 in the rear.
mkmilv1972
