I think the previous owner had oil pump or pickup seal work done before I bought it because at warm idle I am at 50 psi and higher rpm is at at least 60 psi.
I would think there is something wrong with my engine if it was that lowI get about 50 cold, 40 warm with driving and 30 warm at idle.
Sent from my Pixel 2 XL using Tapatalk
70-75PSI cold (seen as high as 80PSI) 55-60PSI warm driving 45-50PSI idle....
yeah 6.0L it has a specialty oil pump though (similar as the LT1 corvette)And you’ve got the same truck with the 6.0 ?
it has aWhat 6.0L do you have? Every NNBS I've owned had just about the same numbers listed.
GM went to the future and came back with the variable oil pumps ..Found this on another forum. It appears my oil pressure is on par for an LY6 6.0L:
For oil pressure it depends what engine you have for the specs engine hot
L76
1,000 RPM 24psi min.
2,000 RPM 35psi min.
3,000 RPM 38psi min.
*LY6*
1,000 RPM 22psi min.
2,000 RPM 30psi min.
3,000 RPM 33psi min.
For both engines the AFM relief valve oil pressure - as measured at oil sensor location:
Max. 55-75 psi
