Oil Cooler Gasket Alternative
Blk00ss
Our '05 2wd has the oil cooler block off above the oil filter, and I believe its leaking again. The OE gasket was a nice thick aluminum with rubber seal. The replacement gasket is like the pic below. I've never liked these pot metal flimsy gaskets and I do not believe they work near as well as the original OE one that was much thicker. Is there an alternative to this gasket? I'd even consider buying a different block off cap + gasket if that would help. My experience with this gasket (pictured) is they start leaking again not long after install. I've even made sure the OE block off cap is flat and flush.
Buggdave
SLC , Utah
i had a persistent leak at the oil cooler mounting location on the oil pan. I was able to determine that it was not the repeatedly replaced gasket but the hex head threaded bolt on the side. Take a look at this location.
Donal
Americus Georgia
Oreilly offers the Mahle gasket, part number B31872. Other venders may have the Mahle as well. Should be about 9.00
OR VietVet
Multnomah Falls
Military
Willamette Valley
Andre Mallory
