Oil Cooler Gasket Alternative
I don't see what the big deal is. The radiator leaking internally is extremely rare. Even if you look around here there are almost no posts about it. This is not something I would lose sleep over at night and delete cooling systems, at least with the OEM parts. I would never use an aftermarket radiator and the aftermarket oil and transmission lines look even cheaper quality. I just changed my radiator to one with the oil cooler to add it to my 2008. Buy the OEM parts and there's nothing to worry about, they're not even that much more money on Rock Auto.
This.
When my radiator cracked, I wanted to replace it with one that was a little thicker and with the engine oil cooler. Rock Auto sent me one that wasn't as advertised. It was OEM, but the same thickness as my stock one. I sent it back and ordered a Denso that was thicker and had the EOC. Denso is OEM on a lot of better import brands, so I'm not concerned. It was much cheaper, too. I got the rad and the GM OE oil cooler line set for right at the same cost as just the [incorrect] radiator.
The ICT Billet block-off went to my buddy and on went the OEM-ish oil cooler. No problems yet and with plenty of 70+ PSI events.
I think the only issue with the internal coolers would be if the truck has something like 300,000 miles or something. I’m sure they’re like everything else- with enough time and heat/cool cycles they will eventually fail. I’m sure it’s rare but the consequences of when they do can be catastrophic. I bought a Level 3 trans from Performabuilt and their instructions state the warranty is voided unless you bypass the internal trans cooler and install the supplied external one. No explanation why. So I called them and their explanation was they do see them fail, and what it does is instantly destroy the frictions in the trans. And it’s extremely easy to spot. They said they’re probably looking at vehicles with extreme high mileage but regardless, it happens. Since they said it’s easy for them to spot if that’s the cause of the failure, I figured I’d just replace my 150k rad and take the extremely small chance that a new OEM rad would fail internally. I wanted to keep the ability for the rad to warm up the trans fluid in cold weather. And there’s no way for them to tell if my rad is bypassed, only if coolant entered the trans. FWIW I have seen members here deal with this failure on more than one occasion, as well as the occasional leaking external PS cooler or leaking radiator. I figure if an external cooler can fail, so can the ones inside the rad. I’d rather not take the chance and run 200-300k on one myself just because of the consequences of a failure. I believe in preventive maintenance.
Maintenance, indeed. The internal coolers are metal and, therefore, subject to corrosion. Those that don't properly maintain their cooling system risk the aged coolant becoming corrosive through chemical and/or electrolytical means.
Mudsport96
40.923,-89.488. Illinois
I dont believe an oil cooler actually adds any longevity to the life of an engine.
My Silverado doesnt have one and at 400+k miles runs great. Pulled a trailer with all sorts of lawn equipment for hundreds of thousands of miles in yhe summer heat. So if someone feels removing the cooler will avoid future leak issues go for it.
There’s also the ones that fail even if the vehicle has been maintained. Here’s one that just happened to a member who bought his truck new and has had the dealer maintain it for its entire life. The internal trans cooler failed and he has radiator fluid and coolant mixed.
No doubt- shit happens. But failure from these, especially from a defect is extremely low, as you pointed out. If you're one to not gamble at all, block it off. As @Mudsport96 mentioned, it doesn't make all that much of a difference in the majority of situations. I'm like you and take the extremely small chance regardless of how little difference it might make. If GM engineers saw enough of a need for it in heavier-duty situations to design one, then I'd rather have it and not need it with how I drive mine.
Yep me too. These trucks were extremely well engineered imo otherwise you wouldn’t hear of them regularly racking up 400-500,000 miles easily with just regular maintenance. Thus the reason I replaced my radiator with a new OE one at 150k. There’s no way to inspect the coolers that are inside it and I’d rather not take a chance but in reality I probably didn’t need to; after I opened up my old radiator I could see those coolers looked new. But no sense taking chances. I have done that with a lot of the parts on my truck. When I did the rear wheel bearings at 160k, I opened the old ones up and I swear they still looked brand new. I’m sure they were original too. Every single bearing was still perfect with no wear marks. I’m a firm believer in preventive maintenance like you.
BurbyRST
