Oil Leak around filter?
Gurrzt
California - where GOD and the sun always shines
If the oil is seeping from the top of the filter, it MAYBE a filter gasket issue. A lot of times (due to heat) the filter gasket dislodges from the filter, and sticks to the engine block itself. Unknowingly the new filter (with gasket) is installed over it, consequently "a leak of oil".
JMHO
jtbadowski
I had a leak there that came from the oil cooler connection block right above the filter.
I also had a bad rear seal on my differential and it was flinging fluid that was seeping out of the seal. the filter and seal are right next to each other. worth a look, a dry differential is an expensive repair
MichaelSE
2010 2500
Tucson
Not sure I understand, do you mean a bad rear seal of the engine (where the torque converter is) or a bad rear seal of the transmission (where the driveshaft is)? The oil filter and diff are nowhere near each other.
Sureconnect
