Coolman1987us
The Amazon link in the same post? It brings up the ict one with no hole.Yup. I left the first link as it was to the one with the hole on Amazon.
How are you so certain that it is not the rear main seal? There is also a rear cover gasket that leaks, and it is just as hard to get to as the rear main. When I replaced mine, there was no way I could verify the rear main for certain. In fact, the rear cover gasket was leaking more than the rear main.Have a 2007 yukon denali 6.2 liter. Have an oil leak that isn't the rear main seal. Trying to figure out where it could be coming from. Oil drips off of the oil filter but the filter is tight. 2 pictures kind of show you where it's wet on drivers side. Thanks
If there’s no evidence of a leak *inside* the bell housing, we can generally rule out a rear main seal leak on these engines.How are you so certain that it is not the rear main seal?
I could not see any evidence of my leak inside the bell housing. This is because it drained down the back of the engine. See post 112 here:If there’s no evidence of a leak *inside* the bell housing, we can generally rule out a rear main seal leak on these engines.
Double gaskets?That thing above the oil filter is sopping wet, that's the oil cooler block off plate like others have said. I would suggest looking and making sure that isn't the cause of the leak.
Also.. what in the world is this thing? Are my eyes deceiving me or is this a sponge that someone put in place to hide oil from dripping on the driveway?
I think it's just baked on oil residue. If you look at my images of the oil filter (conveniently from that post #112) you will see the same casting, but cleaner.Double gaskets?
I did that once...... what a freakin mess, at least it all came out in the driveway (instantly) as I was backing out to take it around the blockDouble gaskets?
Been there myself.I did that once...... what a freakin mess, at least it all came out in the driveway (instantly) as I was backing out to take it around the block
that was a learning lesson, particularly becuase I was broke as a hell and could barely afford the oil I had just put in it.
That made it a habit to always double check.....
