Oil pan gasket replacement
Bigbertha78
Bigbertha78
Maxclass, just as everyone said, you do not need to drain any fluid from the front differential. Just place a jack under the front diff, remove the bolts that hold the axle to the frame, then slowly lower the jack and axle down. It will only lower a couple inches down and rest on the frame. Which is just enough room to remove the oil pan. Hope this helps.
Crcz71
Anderson SC
Quick question for this who have done this. I have an oil cooler and the This is the gasket I ordered for mine in the pic. It appears to have the oil cooler gasket made on am I correct? Plan on replacing the gasket this weekend also what else should I replace. Thanks.
Crcz71
Anderson SC
Thank you. I thought the two holes in the pan gasket would be it. Also I assume I need an O ring for the pick tube as well?
Yes you will want to replace the pickup tube o ring while you’re in there. It’s a separate part if that’s your question.
Crcz71
Anderson SC
Yea I knew it was a separate part. Thanks for your help I already had the oil pan gasket didn’t realize I needed these other two. Wanted to get everything ready for the weekend thanks again for the help guys.
nomadfam80
