I guess I'm just confused/not 100%...
My DoD was turned off via my BlackBear tune, and for as long as I've owned my Yukon it's had slightly lower than average pressure than normal (if that's a thing) .
30-35 psi at idle when engine up to temp, and 35-40ish cruising around. I don't really beat on it so I'm not looking at whatever it's max would be in 3rd gear at 6200 Rippems*.
I read here a little while ago that a high volume pump will give slightly lower oil pressure numbers across the board, and took it at face value.
*Rippems = RPMs
