I dropped the pan which was much easier than expected. Didn't have to drop the axle more than 2 to 3 inches.
I was hoping that when I removed the oil pickup screen assembly nuts/bolts the o-ring would be so bad the screen would just fall out. Not so, I still had to wiggle it out. The o-ring fits pretty loose on the tube and loose in the pump hole, but will stay up there, so I am guessing it is still bad, but is it bad enough to lose
all the oil pressure?
Also, for as black as the oil was I expected to find a half inch of sludge in the pan. I don't think it looked too bad. I did find some odd small pieces of metal in the pan. Some looked like solder balls. I'm going to see what is iron, what is aluminum, save them, and take some picture after I clean them up.
