olliec420
- Joined
- Apr 12, 2016
- Posts
- 185
- Reaction score
- 139
Makes sense. It doesn't after it hasn't been running for a while. Been doing it since I got it almost 30k miles ago so Im gonna let it ride for now.That’s a lifter knock - usually caused by bleed down in a lifter until it gets oil pressure again. If it makes the same noise every time you start it, it’s likely telling you that it’s time to replace it.
As to your oil pressure fluctuations, we’re all chasing a ghost until you get a mechanical gauge on that thing and ride around with it for a while. Could just as easily be an electrical/indication problem as a mechanical one but I can’t think of anything mechanical that would cause a fluctuation like that except for the pickup tube o-ring.
The fluctuations have been going on since I got it and I have the paper work from the previous owner. When he took it in for engine rebuild from the oil consumption problem damage in 2013 or 14 or whatever, on the tech notes it says "customer noticed oil pressure gauge/needle fluctuations bounces" so it has been doing it for a decade+. I guess if there was gonna be damage from that it would have happened by now.
Im gonna put my scanner on it one day when Im driving long haul and when it starts doing it look at the scanner numbers and see. Will report back with results. Not to fix necessarily but in case anyone else needs it in the future.
