Marky Dissod
Old oil never makes as much psi as new oil. Older it gets, less psi it makes.
Idk it’s like, maybe around 30 ish as of right now it’s acceptable since like I said I just did an oil change. Drove 300 miles around Galveston and Houston. HOT idle after 2 hours of driving with this fresh OC in idling just a hair above 20 PSI. Normally running idle to 35 it’ll shoot slightly above 40 psi. And it’ll run at 30 or so idling at 55 psi. Rear end not sure. It’s a z71 has the locking rear differential via traction control button. It’s a 2WDThose value look perfectly normal for the mileage you have. What does the pressure goto when cruising at 55pmh? How about idle to 35 mph? Do you have a standard 3.73 rearend?
Is your pressure fine now? Post sensor replacement.Mine was recently intermittently going down to 20 psi before I replaced the oil pressure sensor. Maybe the heat when the engine is warmed up is affecting the sensor but I don't know about the new oil/old oil aspect.
