oil pressure problems
juniorm4859
San Antonio TX
hi guys my name is junior and i accidently bumped into this forum by accident and im hoping u guys can prolly help i have a 04 chevy tahoe w/ a 5.3 in it and im having problems w/ my oil pressure my guage reads at idle 22-24 psi and when i take off it goes 2 normal like 38-40 psi and the other morning i turned on the truck and the lifters were knocking pretty bad for about 30 sec then evened out my buddy mechanic says its da oil pump and another 1 says its da screen and another buddy says i need an oil change but i just did the change about 2300 miles ago so im stuck any help would mean alot thanks guys oh and if any1 has questions about car audio let me know i manage a car audio shop called precision car audio
blueflamed03
Oklahoma
welcome Junior. Sounds all normal to me. The clatter you hear is the normal piston slap. Very common, even mine does it on start up. As long as you have ample pressure, which it sounds like you do, your good. Oil pump out is no oil pressure at all. :)
juniorm4859
juniorm4859
San Antonio TX
Ok coo man I appreciate that by any chance also would u know where I can find an ss bumper conversion for da truck
juniorm4859
juniorm4859
San Antonio TX
Well man I'm sad 2 report but on Tuesday I still decided 2 look into dat oil pressure it was really bugging me so I bought da oil pump and ect. So took it apart and low and be hold once da timing cover came off I find that water has been leaking into my oil so I spoke to. Couple of my friends who wk at gm and Cadillac and they both said the same thing that it might be da head bolts r cracked that this year model truck had a bad head design so yeah if da heads r leaking than I have 2 get heads if I get lucky and its da head gaskets than just buy da gaskets and get da gees resurfaced so hopefully Monday I find out but thanks 4 da advice man I really still appreciated ur help
Gordy
If they are Castech heads then you will probably need new heads. There was a bad batch of Castechs small percentage that had bad casts with pourosity leaks. Did you routinely have to add antifreeze, white smoke out of exhaust. Obviously there was antifreeze in the oil. Plenty of info on here do a search on castech.
juniorm4859
juniorm4859
San Antonio TX
just recently i had 2 start adding antifreeze and it rarely threw a puff of white smoke so it was weird i never knew it was that and when i drive it never smokes only been a handful of times where when i start it it throws a puff of smoke but thanks 4 da heads up ill look into it right now
