Oil pressure readings
DallasTahoe
Just curious as to what my gauge should be reading, I need a baseline so I can get a jump on it if need be, after my engine is warmed up mine reads about 20 at idle while in gear, and about 40 on the highway doing 60 or so @17-1800rpm. I think it's low but I need some help to be sure. Thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i am at 273k and about the same roughly just a little higher with revving. factory minimums are 6psi, 18psi and 24psi at1k, 2k, 4k respectively. but if they drop another 5 psi i would work on a high volume pump or re-bearing the engine along with a normal pump.
DallasTahoe
DallasTahoe
Ok thanks Sunlit that puts my mind at ease!
willua11
Alabama
What oil are you using and what oil do you recommend Sunlit?
DallasTahoe
DallasTahoe
I'm using cast roll Getz high mileage synthetic blend 10w-40. I replaced the oil pressure sending unit, now it shows I'm getting 40-45psi at cruising speed and about 15 at idle in gear
Roscoe2352
