Oil Pressure Sensor Keeps Failing with Oil Leak
OutandAbout
I need some help with this. 2005 Tahoe Z71 with the 5.3 gas. I am on my 4th oil pressure sensor in 3 years, second in the last 4 months. Same problem each time, oil leak at the sensor connector. Oil is inside where the pigtail plugs in. I notice the small spots on the floor first. Eventually the gauge starts to misread due to the oil in the connector/pigtail. I have been replacing them with ACDelco PN 12677836 and I have the correct socket. There is no screen that I can see or am aware of on this engine below the sensor. It is not leaking around the threads, it is inside the connector.
Either I am doing something wrong when I replace them, something else is causing the same failure across multiple parts, or the parts are just crap. Anyone else experience this? HELP?
There shouldn't be a screen on an '05; that's for AFM engines.
Has one of the sensors contaminated the wire connector, pushing oil into the wiring, and oil is possibly leaking back to the connector from the wiring? Might consider replacing the pigtail and a section of the wiring if that's the case.
O
OutandAbout
Maybe possible but the last one I put in was November and I sprayed the connector with cleaner and let is dry overnight.
The oil spots showed up again last week. Seems like it's enough oil to not be residual from the harness/pigtail but its something I had not considered. I have not ever replaced the pigtail or harness section.
Has anyone had luck with another part number or manufacturer of the oil sensor?
mattbta
Frisco, TX
Where are you acquiring your Delco part? Amazon is risky for fakes. I use summit or eBay seller partscenterplus (chevy dealer in AZ) when buying sensors.
EDIT: 26 lb ft torque spec
Long shot, too - the cam position sensor is next to the oil pressure sensor and can leak:
Awesome clear pic!
O
OutandAbout
Dumb question, but what is the operating oil pressure? Does it ever go high?
I don't have an external one to test with. According to the cluster gage anyway, I'ld say roughly 30 idle, 40 cruising, 50+ if I'm putting it to the floor and the trans kicks down, then it goes back to around 40. Is that right?
O
OutandAbout
Yes, like @Fless says, no screen. Where are you buying the sensors? So many counterfeits out there.
eBay and Amazon. Amazon from the ACDelco store, but sold by a third party. Ebay from Auto-Parts_US Do you think they are counterfeit? I should just get one from the dealer?
I've tried to get part covered on warranty from one seller, and they refused because I installed it myself. The (genuine) AC Delco part 12677836 has a 2 year from purchase, unlimited mile warranty.
kirkdc
