OK, Bought a 07 with a couple problems today.
SpareParts
SpareParts
North Idaho
I'll never be stuck in a muddy water filled pothole ridden parking lot again in the rain:gr_guns:
There is not much holding that cable on but now it is never coming off
SpareParts
SpareParts
North Idaho
I'm going to FINALLY start on my suspension lift and nearly a complete rebuild tomorrow. Kinda exited to get it going. Plan on taking 2 or 3 days to do it as im in no big hurry as i have the week off and the longer it takes me the less wife stuff ill need to do.
Here is how she looks today and measurements for the center of the wheel's to the finder.
SpareParts
SpareParts
North Idaho
Got both sides of the suspension off today but it looks like ill be waiting till Wednesday to put it back together.
The lower spring isolator was gone on both struts and 1 of the upper dust boots is torn.
Ordered new Dust boots, Bump stops and lower isolators.
One strut i could easily push down and about 2 inches from the bottom it felt like air is in it. It extended very slow!
The other side was a real pita and came apart when i pried the bottom off the A arm. No wonder that side felt week but actually the suspension did not feel as bad as the old struts are.
SpareParts
SpareParts
North Idaho
Got the rear mostly done. Nothing to hard.
I could not get the rear end to drop enough to get the springs back in. After thinking about it, i ended up loosening the rear control arms and the diff dropped no problem.
Wanted to get the frame wire brushed and undercoated, but around noon it started pouring rain so had to stop for the day.
Forgot to mention front strut springs removal.
This tool takes almost all the scary out of doing front struts. The tool works WAY better than the two flimsy rod style.
As an Amazon Associate we earn from qualifying purchases.
SpareParts
SpareParts
North Idaho
Changed the diff mount brackets today among other things needing done.
They have to be one of the hardest things to do. I could not do it alone and had to get help from my son. Luckily, he goes to work at 3pm and stopped by around noon to help.
I am going to need a new diff though. Cant believe i never noticed this before.
When i first got it and checked the fluid it was almost empty. Filled it thinking in the spring i would change seals.
Anyway the pic tells the rest of the story except the RT axle just slides in and out. Whoever put that diff in did not put a snap ring on the axle. It has been fine this long so another couple weeks should not hurt till i replace it.
SpareParts
SpareParts
North Idaho
This is how Cracker is sitting now, waiting on parts.
Rear is nearly done. I need to put the wheel well liners in and once i drive it a few blocks tighten all the bolts up connected to a rubber bushing.
SpareParts
SpareParts
North Idaho
I could not take it knowing the front diff was wrong, so made a trip to the wrecking yard today and scored the only AWD, GU6 front diff they had.
Picked up 4 wheel height sensors. I did watch live data driving and mine are good but spares are nice!
Also, Cracker has the code CE1 for rain sensing wipers but the sensor in not there and my mirror compass only works part time. So i grabbed a complete mirror with the rain sensor.
Guess ill see if it works or not.
Anyway, got it all for $200 bucks.
SpareParts
SpareParts
North Idaho
Here how she is sitting today. Far from done though. Got the new diff installed Still need.
Make new Height sensor rods. Adjust the track bar about 1/4 inch shorter, put the wheel well liners back in, check all bolts but
I think i have a problem im not sure how to solve.
I have only moved it about 5 feet forward and back so maybe i need to get it around the block a few time and look for bumps to drive over.
The front end seems to be very stiff and almost not moving up or down and is almost fully extended. If i bounce on it best i can it does not move.
2 things i can think of.
It just needs to be driven to re settle the front springs?.
The dust boots are new. I also put lower spring isolators on and the springs may not be fully seated yet.
The old struts did not have any so i assumed they needed to be there. Maybe not? Some pics show them.
The upper lift block is 2 1/8 thick and it could be it moves the strut down and at the bottom out further from where it is supposed to bolt up to the lower control arm.
Because it moves the bottom further out you need to really force it back to get the lower bolts in.
Its like the lift block needs to be 2 1/8 thick on one side beveling to 1 3/4 on the other side so the lower strut is more inline with the lower mount.
I do not think a guy can put the struts back together wrong
RLyukon19
