One hid is flickering...
BlackLac
I have 55w hids. The light on the driver's side, which is closest to my battery, flickers, but the passenger side hid does not.
I want to do hids in my fogs but I want to fix the headlight first, because if I cannot, then I will buy 35w hids for the heads and fogs in hopes they will match and fix the problem.
I like the brightness of the 55w hids though, so I would prefer to fix them.
Help
Z-56 Hoe
What do I do????
Houston
my passanger side on my truck does / did that i was told it had something to do with the ballest. Mine diddnt always do it just some times. is yours the same way?
TunasTwins
2005 Tahoe LS
Atlanta
Mine flickered and then the bulb died. Change the bulbs and order a new set from DDM. I got the exact same advice from another member a month ago.
NoPh33rRaCiNg
Kent, WA
troubleshoot it... swap bulbs from the other side see if it does it, then swap ballasts from other side...
CdnDenali
For me one side didnt work (when the parking brake was released), but if I turned the headlights on (both lit) then started the truck both would work. Just waiting to send the ballast out for an exchange from DDM. I sure miss them.
blanchard7684
