Only in 4WD Noise
Vette66
Fresno, Ca
I have put my 02 Yukon XL into 4WD before when I went to the mountains but did not notice any noise a couple weeks ago. Well yesterday I went to the beach and drove around the beach for a couple miles. As soon as I put it into 4wd high I heard a worble sounds, sort of like a warped rotor for brakes, it did not seem to slow me down any and got more consistent as speed increased. As soon and I put it back into 2wd the noise went away.
So does anybody know what this is? Low fluids? Kinda at a loss here.
Any help is appreciated.
Chris
03Yuk0n
Hey, not here to jack the thread, but I got the same problem in my 2003 yuk0n. Pretty much the same symptoms as Vette66.
thnx all
k0n out
Vette66
Vette66
Fresno, Ca
Maybe if 2 of us have it now, many have had it in the past. Hopefully a easy cheap fix, haha. Always welcome in my threads..lol
BTW I did search for answers and I got nothing on noises from the 4WD when in engaged so yes I have search a bit.
03Yuk0n
Hey Vette yea thnx, same here did some research but still ended up with nada. Lol yea hopefully someone will chime in later on.
MABX13
well my truck is only 2wd and the only closes i get to 4wd is the traction assist button :D
Donnie Yukonie
Yates Caretaker
where is the noise coming from? more center or forward of the vehicle ? The most probable cause is the transfer case bearings going bad. The NP246 Tcase has issues from the factory known for the pump to wear through the magnesium casing , check to make sure yours is dry and filled with fluid , if so check the color (should be blue) Auto tracII report back with your findings
Vette66
Vette66
Fresno, Ca
Forward of the cab. I will check it out in the next couple days and report back.
Rd05lly
Auxvasse MO
This is a picture of inside of 246 transfer case. With pump rub
Check the front diff lube and u joints.
Dornan
