I've searched the forum but surprisingly came up with nothing on this. Out of nowhere today, the Reduced Engine Power came up along with check engine and trac. control disabled. I made it to Advanced to check the codes and got back 4 codes- P0120, P0220, P1516, P2101. I found a little just from googling the codes. Could be a bad TPS or poor connection at the terminal.
Anyone else had to fix this problem? Can't decide if I want to dig into it myself or let a shop **** me. I've got my money on a bad connection, but I don't know if you can replace the wires that go to the TPS or just fix the broken connection.
---------- Post added at 04:47 PM ---------- Previous post was at 03:17 PM ----------
Think I may have found the fix. The yellow wire was broke inside the insulation about 3/4" away from the plug. Hopefully this takes care of everything.
