P0304 P0443 white smoke misfire 07 Tahoe 5.3 4x4
Jps0039
Jps0039
Yeah have to wait till I have my dads help to pull the head. Once we are in we will know more. I’ll keep y’all posted for sure and appreciate all the advice. A rocker arm wouldn’t make it blow smoke would it?
Jps0039
Jps0039
10-4, I’ll be looking for bad casket and collapsed lifter in this case correct? Anything else I should look for?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Do you man gasket and not casket? Spell check. The valve cover gasket will not come in to play on this problem. You can look for the rockers movement to see if they all move the same amount. Look for a broken valve spring. Look for a rocker stud or rocker problem.
Jps0039
Jps0039
Meant to say the #4 rocker arm is seized up. We are about to pull it to examine the push rod
Jps0039
Jps0039
Pulled valve cover. 4 the rocker arm is seized up we are about to pull it.
Pushrod is straight the rocker arm is tight. We are thinking probably a collapsed lifter. Going to try to use an additive to free it. If that doesn’t work we will replace lifter
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Perfect time to at least replace all lifters if not the cam as well. When you remove the lifter make sure you get as good a look as possible of the cam surface.
kjetilaf
