P0340 Code On New Motor...WtH is going on Here??
Biggwaukegan
Banned
Land of Abe
Guys I had my codes cleared and P0340 came back. Camshaft sensor code. Should I replace the camshaft sensor or DO I have to relearn my sensors with a scan 2 tool? If so hows that done, where should I take it? Help me here I cant go 4 emissions til this shit is str8. thanks
steamroller
The South
Check the wiring before you start throwing any parts at it, if the sensor was unplugged for any length of time check the connectors for corrosion.
Biggwaukegan
Biggwaukegan
Banned
Land of Abe
Ill check the connectors in a few mins. I doubt its that because I found this
Below is the text from GM Service manual for 1997 Chevrolet C Pickup 5.0L, 5.7L, and 7.4L
Accordind to this you don't set the timing but the timing offset.
You need a "Scan Tool" that plugs into the truck and can read the data from the trucks computer.
Besides from that, it looks like a normal timing procedure.
You might be able to borrow a scan tool from a parts store, or at least use their tool and do it in their parking lot.
Setting Timing
Camshaft Retard Offset Test
The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
With the ignition OFF, install a scan tool to the DLC.
Start the engine and bring to normal operating temperature.
Important
Cam Retard Offset reading will not be accurate below 1000 RPM
Increase engine speed to 1000 RPM.
Monitor the Cam Retard Offset.
If the Cam Retard indicates a value of 0° ± 2°, the distributor is properly adjusted.
If the Cam Retard does not indicate 0° ± 2°, the distributor must be adjusted.
Adjusting Camshaft Retard Offset
With the engine OFF, slightly loosen the distributor hold down bolt.
Important: Cam Retard Offset reading will not be accurate below 1000 RPM
Start the engine and raise engine speed to 1000 RPM.
Using a scan tool monitor Cam Retard Offset.
Rotate the distributor as follows:
To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
To compensate for a positive reading, rotate the distributor in the clockwise direction.
Repeat step 4 until 0° ±2° is obtained.
Turn the ignition OFF.
Tighten the distributor hold-down bolt to 3N·m(25 lb. ft.).
Start the engine, raise engine speed to 1000 RPM and recheck Camshaft Retard Offset.
steamroller
The South
Not saying it can't be that, but if the CMP retard/offset is off a P1345 code will be set. It can't hurt to get that squared away anyways
Yeah just double check that no wires were pinched back there between the engine and trans when the engine was installed
99Yuk
Northern Ontario, Canada
When setting up the timing cam retard on my new motor, I had the apprentice adjust the distributor, while I was in the cab revving to over 1000rpms and yelling out a running commentary of the cam retard setting. We had it close to 0°, and I wanted to stop because it says +-2° is good, but the apprentice kept going until we had it set to exactly 0°.
Anyways, it's a lot easier with another guy.
and +1 on a loose/corroded electrical connection probably being the real problem.
Biggwaukegan
Biggwaukegan
Banned
Land of Abe
Ok. Im gonna check all wires again today. Bet its not that though. Bet its the fact I need my camshaft retard timing set right. but Ill check all the wires again. Gonna replace the sensor and set that retard if the wires are all good.
Biggwaukegan
Biggwaukegan
Banned
Land of Abe
you fellas...all is well....cleaned connection. relearned codes and shes not lighting up the service engine light. Gonna have to drive it for a day or 2 then its emissions time. thanks to all that chimed in
Biggwaukegan
Biggwaukegan
Banned
Land of Abe
Ok lets wrap this thread up. Finished up everything and just got back from emissions here in wisconsin. thanks
Tssonebay
