Just want to report on my '07 5.3L that at 130k miles I got the P0521 low oil code while highway driving in 5 degree weather (which this Tahoe has never seen). At highway speed at 2k RPM the oil pressure slowly dropped down to ~18psi at lowest. 2300 miles on current oil. After reading forum I assumed I was ok to continue trip.
I run Mobil-1 synthetic 5-30 and any mid-grade filter changing oil 4-7k miles.
I decided to run Seafoam for last 200 miles (no help in dash pressure). Added cheap quart of oil and pointed rig down hill to verify oil pickup oring in pan was ok, then change oil / filter before jumping into the new oil pressure sending unit and screen.
HAPPY TO REPORT: Simply drained oil and replaced old STP Extended Life Oil Filter S10060XL with WIX 57045XP oversize filter and fresh Mobil-1. Boom...instant oil pressure just from new filter so I assume filter was faulty or clogged.
Low pressures indicated in park: Idle 17psi, 2k 22psi, 3k 33psi
After oil/filter change pressures indicated in park: Idle 32psi, 2k 47psi, 3k 53psi
FYI. I added oil catch can so now I'm going to send out ECM to remove AFM V4 function as CYA.
I love this forum. ♥
