Parasitic draw
BG1988
Of course it does or it would lose its memory. Duh. Some other modules draw a little, too, to retain critical settings, which is why a very small amount of power is always being used. That's normal and should be less than 50ma. In the PO's case, there is too much being drawn.
well he has an after market radio so you do have to run a key ACC on wire ... other wise if it was jumpered it will be "on all the time"
a hissing noise is normal that means the amp turned on from opening the door ( that happens on other GM cars and trucks as well)
BG1988
I was thinking the 12+vDC had a jumper to the ACC on causing the draw... i.e always "on"
RefrigerationDude
Im having a similar problem with my battery needing to be jumped off every few days in a 01 Tahoe. Im about to go out and check mV's across the fuses and go from there....
3 year old battery, and I'm going to go have my charging system checked just as soon as i find out why it suddenly started overheating this morning...FmL
Mickey_7106
Mickey_7106
Bay Area
All my aftermarket HU are wired as if they were stock. I don't run anything extra.
Also ive never heard the amp make any noise on any car ive been in. You must have some really great ears
Jeff O
I went thru this on 03 Tahoe. There are multiple things that could be the cause. There are 3 computers: the Radio, the IPC and the main body computer. The Instrument Panel (although you disconnected it.) for your year should be sent to a repair service to be checked for bad solder joints and also the meter movements replaced. The main computer in my case seemed to be the big problem. It is located on the left side of the engine mounted to the frame. The connectors are not totally protected from water infiltration and corrosion on 6 pins (a couple almost totally) was found to be the culprit. The radio & MBC are a a little deceiving when doing current checking. They may draw 2.5A when initially shutting down and take maybe 30-90 sec to go to almost zero. Residiual draw is normal and should be between 30-50 milliamps. When shutting down, remove the key from the switch, even that is sensed by the computer and 'readies' the engine for start which causes current draw. Ck for other threads on this forum about this same prob. Good Luck.
davidavidd
CO
Does anyone know what the acceptable parasitic draw is for a 2001 Tahoe? My brother has been having on going issues with dead batteries. he was told by some mechanic outside pik npull that it was the SEO1 fuse ( guess he used some sort of test light method)
Anyways i had the truck sit over night and currently the 25A RDO AMP fuse is consistently pulling 1.0 mV which translates to 218 mA according to power probe tek website. The battery was at 11.6x Volts when i tested and the radio was removed and disconnected last night.
I know this method can be inaccurate, im waiting on a clamp meter and noco genius 10 battery charger to be able to perform a more accurate test
My Tahoe 2007 draws 15/20mA on sleep mode (30 minutes after being turned off), I don't know if your model includes it but check: digital radio tuner (Xirius XM), Onstar module and any aftermarket radio.
Mickey_7106
Mickey_7106
Bay Area
Thanks yall,
I let the truck sit for about 2 days with the large plug with the blue tab disconnected on the amp. Truck had. 12.58V when i checked this morning. Started with 13.03V after 10 hours of over night charge using a noco genius 10 2 days ago. I want to think it's safe to say that the amp was the culprit for the battery draining. Before it couldn't go more than 3 days.
While on the subject, does anyone know the best way to remove this amp? Looks like i might have to tear out the whole dash
Yukon_
Missouri
Similar issue on '07 Hoe - Ended up being the negative battery cable was corroded on the inside of the jacket, couldn't see just by giving it a glance. Peeling jacket back down revealed it. And having it load tested. Once replaced - no more issues
blanchard7684
