PC valve and tube
YXLSLT
I was switching out PCV valve. Takes all of one minute. However I bent and broke the tube. Oops! Autozone says they have a flexible vacuum tube that could work possibly. The other choice is GMC dealee on Monday. Really dont want to wait that long.
Suggestions on if I can make something else work?
Scottydoggs
NJ
vac line that fits tight will work. cut off like 2 inches, push the busted ends in each side of the vac line. done.
Scottydoggs
NJ
im huge fan of any repair thats less then a dollar. lmao
you can also patch up your washer fluid lines when they break the same way. and they will break one day if not already.
certa
