Picked up an OEM looking Backup camera worth $700 for $30 :)
NJ04HOE
Paterson, NJ
damn so what one of these has worked 100% so far great hahaha so mine sitting in my living room has a low success rate of working
mine works with no issues, I put a switch on it since I didn't want it on all the time and I didn't do the reverse light hook up just in case I wanted to play with it whenever.
jESse
i like cheese
michigan
mines worked perfect since i put mine in. mines grounded to the inside of the rear passenger d-pillar near the bottom. just self tapping screwed into the metal. kinda behind the taillight area. i'm getting my power from a splice tap off of one of the cigarette lighter power supplys and then running through a switch and then to the camera. never had any problems yet
Maverick7687
Knoxville, TN
Has anyone tried the camera with a different video source like another monitor or head unit? Wondering if it's the camera or the included monitor causing the problem.
DenaliAK
Colder than you
Alaska
I think it's the control box in between, actually. If I could skip the box somehow or use a different one, I think it might work.
BOSS
The People's A D M I N
Dallas
Gunna do this tomorrow when JK fixes my alarm modules. Wiring it up to my DIN and switching it for towing.
B
NathanJax
Vacation Nathan
Administrator
Jax, Fl
All you should have to do is figure out which wires in the s-video cable are power, ground, and then the video negative and positive and you should be able to wire the camera to any monitor. I guess it would be the same for the LCD as well...
04Hoe
Mine works perfectly ( knock on wood ).
I had mine installed.
M3PO
Mid West/Cow Town USA
Has anybody found another source for these?
Not sure about the one originally posted, as the post is almost 2 years old, but if you do a search on ebay there are tons of options. Also, it seems most of my local auto parts stores stock one or two different types.
When I got my Denali late last year I was all hot and bothered to get one, but the thought went away; well until I almost backed in to my new trailer on the driveway. Luckily there was a large plastic trash can in between my truck and the trailer!
Adam 442
