Sam Harris
Thems purty
Thems purty
Thanks. Buddy of mine knocked them out of the park. It’s a titanium and glacier black mix.
Ceramic coating???
Mine are titanium ceramic.
Swapped out the factory pads/rotors for R1 concepts drilled rotors and ceramic pads. No real difference in stopping power. As far as I know they were the original rotors. Just crossed the 164k mark.
Also got the tune back from BlackBear. Engine runs smoother at idle and pulls harder in the middle and upper RPM range. Shifting is close to factory when you are cruising around with slightly higher shift points. When you flat foot it you can really tell a difference in the shifts. Much firmer and no delay between gears. I’m happy so far.
Anyone have a parts list for the rear main seal? That’s next on the list as well as a sensor under the steering wheel, so tired of lights on the dash.
Looks good!
Did you bed in the new pads and rotors?
Just some quick stops. I just swapped the pads in my ‘03 Yukon to some powerstop ceramic carbon fiber pads and did 5 quick stops from 50-55 to about 20. Just barely shy of activating the abs. By the way, very happy with the pads! [emoji106]What’s involved in that? I had a shop do the install.
