Please double check my t-case repair plans
ThinkingJack
I am repairing the t-case on my brother’s 2002 Tahoe LT, 5.3 and NP246 case. He’s had the truck since new and it’s well maintained (205k mi). He went to change the t-case fluid the other day and the fill bolt was seized in the threads, rounded, and cracked the housing. I did search this forum and read old threads on it; very helpful. I have rebuilt one GM auto transmission before, and some manual trans, so I am pretty confident in what I’m doing, BUT: I’ve never worked on this exact transmission before.
He ordered the Dorman aluminum replacement, this:
https://shorturl.at/IxlXa
He and I took the t-case out today. When we started to remove it, a decent amount of fluid came out from between the units - red ATF. I understand this to mean the trans output is leaking into that cavity as it should have been dry? Bushing inside the trans is worn and/or the drain back is clogged? So, here’s my plan and questions:
1) I am buying this Transtar t-case kit, which will give me new seals and the paper gasket to the adapter to replace all the t-case in/out seals.
https://shorturl.at/vkwo1
2) What is between the t-case halves? Paper gasket? FIPG? I didn’t break it open yet. We did the water pump and pulled the t-case and called it a day.
3) If I take that transmission mount/middle adapter out, can I access the transmission output shaft in any way to address all that fluid in there? I have looked at videos, and I do not see an externally replaceable seal.
4) I noticed a slight leak on the left at the pan edge, I am assuming a shift shaft seal weeping a bit from above. I saw the tool for that and will replace that while under there.
5) I found some $15/$20 “Case saver” plates to buffer the t-case oil pump ears. Simplified stamped steel versions of the “Merchant” saver device it appears to me. Is that necessary with the improved Aluminum housing?
Also I cut one of the transmission support bracket bolts out; the exhaust and O2 sensor bung prevented removal. I need to get a new bolt and insert it from the other direction. Plenty of room; seemed weird they did that. I was NOT messing with the exhaust to get that bolt out. ;) I will go to Tacoma Screw to try to match the bolt, if not available there, where is a fairly priced GM parts source to order one from (I don’t work on a lot of GM products - just our Mom’s Euinox, though I am contemplating buying a late GMT 800 or early GMT900 Tahoe to replace my beloved Trooper).
Appreciate any advice or checking my thinking.
justirv
If I recall the t-case halves are sealed with a RTV, I don't recall specifics. I replaced the hyvo chain and all rubber. I did add the case-saver for added comfort. If you plan to do the clutch pack, you'll need a special tool (always, right?) to determine proper shimming. J-44295 KENT MOORE SHIMMING TOOL. You could probably have that shimmed at a local shop for reasonable cost. This tool (used) is around $400+.
NickTransmissions
Sin City
The transmission bench
That kit should be correct for your T-case
All the internal components, including the chain/sprocket set, gear set, clutches, etc - cant recall if RTV only or a gasket (Think it's just RTV) - use Permatex Ultra Black if so.
There's no rear transmission seal on 700-R4s or 4L60E transmissions so nothing to service; the output shaft will have a little inboard-outboard play as well as slight bit of side play but shouldnt move in/out much or side-to-side much...
You can use the tool to yank out the seal or drop the pan, remove the 15mm selector shaft-to-rooster comb nut, slide the selector shaft out then pull the old seal out with a flat blade screw driver or small pry bar then install the new seal w/a 15mm deep socket (i think 9/16" will also work). If you drop the pan, install a new pan gasket and filter then reinstall the pan and torque all 16 bolts to 98-100 inch lbs. You will prob need to go around twice to three times to fully compress the gasket...DO NOT use a flimsy rubber gasket or a cork gasket...Only a composite gasket ($2-$5 at hard parts suppliers) or a Victor Reinz molded steel/rubber gasket.
Not sure - perhaps @rockola1971 can comment
Blackk
