Dustin Jackson
- Joined
- Aug 9, 2018
- Posts
- 1,620
- Reaction score
- 1,822
FYI the LM7 cam is a nonAFM replacement but is on the weaker side of factory cams
Thank you so much man. I've worked on cars for years and this is the worst oversight I've made.@03GMCYukonXL
looked through my email and here is the part number for the camshaft I used. It is the highest performance Non-AFM Non-VVT camshaft that GM made for these: 12583623
This is for the 5.3 “high output” motor otherwise known as L33
So I ordered the vvt cam with the kit and I do not have vvt. So I put in the wrong cam. Seems like this is the only thing to explain my issue. I put in LS7 lifter and non DoD valley cover. All that stuff. Just I put in a damn VVT cam because I didn't pay attention when ordering. Also, I did put it back to stock tune and used HP tuners to disable the DoD. That's the only change I made.@03GMCYukonXL I am just now catching up to your story so sorry If I am asking questions that have already been answered.
Get that new cam installed with non-AFM and non-VVT components.
Flash your truck back to stock and use HP Tuners to ONLY disable AFM and VVT.
It sounds like the first AFM disabler you were using only cripple's the emission system to trick the motor to not enter V4 mode but it would still be looking for the AFM parts so that would explain what you were seeing in the first post. I can't explain the problem you were having after using a proper tune to disable AFM.
I'm not as familiar with GM's VVT, but it could be that the VVT cam needs to be clocked at a certain position at idle and it's fixed at the position it's in now. It runs ok at higher rpm. Just at idle there is a miss and runs lean. I would assume it would run rich because it's not getting enough lift and there is too much fuel for the air that is let in...however I really don't know. I can think of no other reason this would be happening. If it was a true lean condition then I would be getting those codes with the AFM enabled on the stock tune, but I do not. I only get it when it is disabled.@03GMCYukonXL Sounds like you are on the right track!
