Post your lifts.
06_2WD_Z71
Update installed z71 springs. So currently have life Keys, passenger torsion bar on driver side, and z71 springs
Good looking truck, better get some spacers in the back though or you will be getting pulled over for runnin' shine.
Abard123
Lakewood Colorado
I bought my 2003 Tahoe a little over a year ago. It already the lift so I'm not completely sure what it is, but I think it is a 5" Skyjacker. I added the wheels and 33" duratrecs. With the lift, tires, and G80, this thing is pretty unstoppable on the trails out here in Colorado.
Countryboy07
Finally happy with how mine is sitting: 38.5 front 39.25 rear - eBay keys, Bilstine 5100's, eBay 1.5" coil spacers, 1.5" wheel spacers, 275/60/20 Falken Wildpeak AT3's on OEM NNBS Sierra/Yukon wheels.
UtahYukon
I'm new to GMC/Chevrolet but I can say I love this SUV. 6" Tough Country no body lift. I went from 33" 37" so I had to crank the keys a little and big hammered the back of the front wheel wells. I will eventually cut the front bumper. It doesn't rub except when turning in reverse, turning on bumps but going straight is smooth. 20160905_200720.jpg 20160905_205518.jpg
06_2WD_Z71
I'm new to GMC/Chevrolet but I can say I love this SUV. 6" Tough Country no body lift. I went from 33" 37" so I had to crank the keys a little and big hammered the back of the front wheel wells. I will eventually cut the front bumper. It doesn't rub except when turning in reverse, turning on bumps but going straight is smooth. View attachment 66533 View attachment 66534
Wow. When civilized society does finally break down, that is the truck I want.
UtahYukon
I read on the inter webs that I could cut to fit... so I did! Cut bumper and cut and ground the tar out of the rear of the front wheel well. If you do this WATCH OUT for the rear AC lines on passenger side.14322779_10202029739461025_4262426629454747074_n.jpg 14264010_10202029739741032_1450758553982675190_n.jpg
OhFourChevy
Houston Tx
image.jpeg Keys, Spacers, Cognito front sways, TJ rear sways, 17x9 4.5" back spacing, 295/70r17, wheels sprayed w/ bedliner, got beat up changing the tires so working on removing bedliner around the lip of the wheel, then polishing the aluminum or removing all and re-painting, shock extenders for now, Bilstein 5100s going on early next week
Coming soon
Spindles, c50r Spring, spohn track bar, ss brake lines, moog UCAs, pitman, idler, tie rod ends, 4.11 gears, tune
Capeles
