Power Stop Rotors any good ?
GMT800 SUV/Trucks
When I did all that work in my Build Thread, I could have used anything at all. Time and time again, I remembered how well the OE stuff works and lasts. Was a no brainer, but I have to admit, more people like the Power Stop than don't but less than half seem to think it is better than OE but the price sways them at times.
I noticed there is a part number called out for the 2013 suburban. I wonder what the difference is.
the ones I linked have the hat drilled also helps dissipate the heat I have had them on the 18 silverado for a while now work great, they will fit the suburban.
I have upgraded to the baer erradispeed on the yukon which work really really good until you get them overheated then there is some noticeable fade which doesn't happen unless you work them pretty hard it's happened to me a couple times driving down very long downgrades with lots of turns. I don't drive like a normal person I drive it like it's a sportscar the work around to not overheat the brakes is to use the transmission grade braking
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I see the added drilling now. Thanks!
Sparksalot
Bastrop County, Texas
So the rotors work for the nnbs and k2s?
Yes, there is no difference, there may have been some weird thing they did in 08? with the calipers and pad size that was a one-off type of deal that I have seen before but otherwise all the 1500's are the same from 07-20 with perhaps very minor differences that would not affect anything were talking a couple mm difference in thickness/height, etc
they will also work on the 00-06 nbs if they have done the nnbs caliper upgrade this includes all lines gmc/chevy/cadillac. pickups and suv's, avalanche. the only one i am not sure on is hummer a lot of it is the same under the hood though
just like pads the fronts are 1363 and rears are 1194 all the other numbers/letters don't matter (size wise) they only denote the manufacturer and pad material used i.e metallic/semi-metallic/ceramic, those numbers are pretty universal but some manufactures use there own separate number
Shadfrmdabull
