problems with the our new yukon
Arc
We just got the wife this 04 Yukon. It does have some problem. One i know for sure is the intake gasket has a leak on the driver side. I already have keys for that. Here are the other I need help with. Figured i would put it all in one post to save forum space.
Driver side front creaking noise in suspension when going over bumps, taking off, or breaking. No bad bushings. and shocks are new.
A annoying clicking noise under the dash. sounds like a mouse clawing at stuff. sounds like its coming from the hvac unit. EDIT: I figured this one out. Blend door. Now do I change it.
Service break booster on DIC. I pulled the fuse to clear it and it came back on a day later. Its has Hydro Boost. I checked the ground and put a washer on the module.
DIC steering wheel buttons dont work. I have no idea on this one.
Thanks for the help guys.
riso79
So Cal
I had the same DIC problem with my 06 suburban. Dealership tried reprogramming it but it didnt work. Needed a new gauge cluster to make it work.
the rest I have no clue about.
newjonwayne
